This guide will walk you through how to authenticate or reauthenticate Searchmetrics in Supermetrics for Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Searchmetrics, you need:
- The Administrator access level
- An API key and API secret
- A Searchmetrics account with export credits
- Every data request costs Searchmetrics export credits, even when just testing queries. Learn more about this in Searchmetrics' API documentation.
Get your API key and API secret
Follow the instructions in the Searchmetrics' documentation to generate your API key and API secret.
Save these credentials — you'll need them to complete the steps below.
- Click Add-ons → Supermetrics → Launch to open the sidebar.
- Under Data source, select Searchmetrics.
- Enter your API key and API secret, and click Start.
- Under Query type, select the query type.
- Type URL(s), separated with commas or new lines.
- Select a country.
- Navigate to Searchmetrics and click Try.
- Click Authorize.
- Click Authorize.
- Select a country.
Connections
- Select a country.
- BigQuery
- The Supermetrics API
