Searchmetrics connection guide
Use this guide to connect your Searchmetrics data to the reports you create with Supermetrics.
To connect to Supermetrics, your Searchmetrics account needs:
For Excel users
Google Sheets Data StudioExcel
  3. Click Create new query.
  4. Under Data source, select Searchmetrics.
  5. Enter your API key and API secret, and click Start.
  6. Navigate to Report configuration, and select your query type.
  7. Add URLs in the "Type URL" field, separated by new lines or commas with no whitespace (,).
  8. Select a country.
