This guide will walk you through how to authenticate or reauthenticate Adform with Google Sheets, Data Studio, and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Adform, you need:
- External API access enabled.
- An Advertiser or Agency user role, as part of Buyer Solution category. See Adform’s API documentation for more information.
For Excel users
- Click Create query.
- Under Data source, select Adform.
- Enter your credentials and click Log in.
- Click Allow.
- Under Select accounts, select the accounts.
When you're ready, learn how to create your first Supermetrics query with Adform.
- Navigate to Adform and click Try.
- Click Authorize.
- If you're authenticating the data source for the first time, log in with the Google account you use with Supermetrics. Click Allow.
- Click Authorize to log in to the data source.
- Select your accounts.
- Scroll down to Parameters.
- Enter your email address and password and click Log in.
- BigQuery
- The Supermetrics API
