Supermetrics Support Forum
Invalid Table Name: Try Using Standard SQL (Sheets)
This guide applies to the following error that may appear in the Google Sheets Google BigQuery connector:
Invalid table name: `supermetrics-demo.xxxx.BINGADS_GEO_20190407` [Try using standard SQL (https://cloud.google.com/bigquery/docs/reference/standard-sql/enabling-standard-sql)].
As noted in the URL from the error text, if you don't explicitly query it as standard SQL, it will run as legacy. To fix this, include at the top of your SQL query the text:
#standardSQL
