Some of the metrics require a dimension to be split by and these cannot be used with scorecards as you can only choose a metric for these.
For example "post reactions" -would require a post level dimension in to the same query to work -and therefore you need to use for example "table" or "bar chart" to be able to use the dimension in this query as well.
