Supermetrics Support Forum
How to create a bar chart
  1. Select "Bar chart" from the toolbar
  2. Draw the area you wish to use for the bar chart
  3. Check that you have selected the correct data source.
  4. Choose the dimension(s). In this example, we select "Week (Mon-Sun)" and "Gender" -with a help of the search tool.
  5. Choose the metric. We choose "Website conversions" in our example.
  6. To make the chart clear to understand, go to "Style" in the sidebar and modify the visual details, like:
    1. Colour schemes
    2. Dimension values
    3. Axis titles on/off
    4. Logarithmic scale on/off
