How can I fetch more than 200 rows of Moz data? How can I avoid Moz quota issues?
For getting more results from Moz and improving performance, you should get your own API credentials from Moz and add them to your request.
Once you have the credentials, set up your Moz connector following the directions in How can I fetch Moz data using my own credentials?. With this setting, Moz queries will be executed using your own API credentials.
